more warrior
Old Jul 1, 2000 | 11:35 PM
300exguy's Avatar
more warrior probs!!!!Tonight after we got our 96 warrior put back togother we tried to start it.It doesn't have any spark and the starter won't engage so we pulled it with our 300ex down the road to see if it would spark nothing.The reverse or nuetral lights won't come on.Any idea please have some!! we got to sell it and the qaudzilla to get a rubicon!!!!!
moded 86 trx250r
moded 87 LT500r
97 300ex
96 warrior=broke
90 blaster=broke
2001 rubicon coming soon yea!!
Old Jul 2, 2000 | 12:28 AM
Mr45auto's Avatar
What did you do to it in the first place? I'd first try checking the main fuse, it's on the left side rear.
Old Jul 2, 2000 | 12:49 AM
PC_350_Warrior's Avatar
ahhh, did you check your battery?!?!?!?! Cuz, if the lights wont come on and no spark, could be the battery!
Old Jul 2, 2000 | 05:18 PM
hmforawarrior's Avatar
Check all your electrical connections. check the starter solanoid, make sure that the reverse lever switch is wired correctly(green wire with white stripe) and grounded. Also be sure that your engine ground wire is hooked up(heavy gage black wire on one of the crankcase screws just under and to the rear of the carburator.
Old Jul 2, 2000 | 07:54 PM
Banshee_16's Avatar
It should still get spark if the solenoid is bad. I just put a new one on my 96 Warrior. Check the fuse, all connections, ground, if everything is good it will more than likley be the stator( i have had to replace mine before for the CDI box.
Old Jul 2, 2000 | 08:04 PM
Banshee_16's Avatar
It should still get spark if the solenoid is bad. I just put a new one on my 96 Warrior. Check the fuse, all connections, ground, if everything is good it will more than likley be the stator( i have had to replave mine before_ or the CDI box.
Old Jul 2, 2000 | 10:51 PM
300exguy's Avatar
Alright we got spark and we got all the lights to work.The problem was when we put the stator back on the magnet in the flywheel pulled the flywheel into the stator cover and it removed it self from the crankshaft.We put a new main fuse ina dn hooked the reverse wires up right.It has a new stator by ricky stator,new connecting rod,the crank was just trued,The only prob now is the starter is dragging real bad I guess it is time for a new one.We just put a new starter clutch in it.Hopefully the sarter stays working long enough to sell it.The starter was engaging but since the flywheel was off it seemed like it wasn't turning over. thanks for all the help guys!!!!!
www.angelfire.com/me3/fmf86trx250r
Old Jul 2, 2000 | 11:38 PM
300exguy's Avatar
WEll i was rong I just went in the woods on it turned the head light on and it blew the main fuse!!!!!!So I am stuck in the woods at night with a broken 4 wheeler.We already used the spare fuse in the little holder.So what do I do?? walk 2 miles so I can get the dang 300ex to pull it home.what could be causing this.It runs great but everytime U turn the headlight on it blows the fuse!!!!!!
Old Jul 3, 2000 | 12:22 AM
Banshee_16's Avatar
There has to be a short somewhere in the light or light wires.
Old Jul 3, 2000 | 02:32 AM
300exguy's Avatar
we took our ohm meter and checked for a short on the outside wires.Do u think there could be a short in the headlight???I only have one wired up because the guy we bought it from cut the ends off the other one to put the headlight on his son's fourtrax 90. so i got to wire that up also.It runs great other than that.It has a small hesitation when U gun it though I have read this is a prob for most warriors is there anyway to fix this??? thanks again!!!!!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
