Blaster Carbuerator Help
Originally posted by: ShadyRascal
You need to loosen the screws on the carb intake and exhaust boots, and rotate the carb so you can get to the bottom of it. Take off the 4 screws holding the bottom bowl on and carefully remove it. The main jet is then exposed, right in the middle.
just so you know, your idle might go up. I found that when i went from a 220 to a 290, might went way up. The idle screw up on top by the airbox didn't do much to put my idle back down. So i went to the air/idle screw, and turned it clockwise and it went right down. I was just thinking about it, and is that screwing it up? Or is it ok that i did that. I also went to the 4 clip on my needle.
THX ALOT GUYS U REALLY HELPED ME ALOT I TRYED THE TOOMEY INSTRUCTIONS AND TURNED THE CARB SIDEWAYS AND I DIDNT SEE ANY SCREWS SO I THOUGHT TO MYSELF IS IT REALLY WORTH SCREWING UP MY BIKE THAT RUNS PERFECTLY FINE THE WAY IT IS SO I GUESS I JUST NEEDED A LITTLE HELP THX A BUNCH....... damn caps lock
