Can i bent the frame back?
Old Feb 5, 2004 | 11:51 PM
Raptorboy4life's Avatar
Default Can i bent the frame back?
I bent the frame on my raptor by hitting a tree how should i bent it back? I could heat it up and bent it or i can pull it in one direction and the other part in the opposite direction? how anyone? it is the part from the engine to the front a-arms on the bottom?
Old Feb 6, 2004 | 12:40 AM
Outlawlawndragster's Avatar
I dont know what you have in the way of tools but it you can lay it out and fasten it down a PORTO/POWER should move it around . No promises .
If you dont have the tools take it to an alignment shop that works on wrecked cars and such they could tell you if it's repairable . Good luck and watch out for trees
Old Feb 6, 2004 | 12:04 PM
sAyIt_fmf's Avatar
depending on where it is bent...I have used jacks, wedges...big pipes...the worst part is getting the frame secured enough to pry on it. Even then your probably going to stress some joints..etc.
A frame straitening shop for autos should be able to help you out.
where did you bend it?
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
bikedad3
Jul 2, 2015 02:15 AM
