Striped oil plug
Old Feb 23, 2004 | 12:31 AM
Spoony's Avatar
Default Striped oil plug
I was tightening my oil plug and it striped out. Can I just take a tap, and rethread it to a bigger size? Then just take a normal bolt and use that, or should I find a bigger plug?
Old Feb 23, 2004 | 01:39 AM
hondabuster's Avatar
There are a few things you can do. Thats one of them, watch the bolt length, and use grease on the tap, and go a turn or two on the tap, and remove and clean the chips off it then go a couple more turns, and clean, until youre thru. You dont want the cut material getting into the motor. Downside is, if it happens again, the hole will need to get even bigger.
Best fix, is to helicoil.
Check out this tech tip, to do that.tech tip
Old Feb 23, 2004 | 01:41 AM
Turtler's Avatar
If I were tapping to a bigger sized thread and using a bolt, I would use a bolt with a sealing flat washer so you dont start leaking oil all over the place. Additionally, I would make sure you havent left burrs in the case or that will cause havoc on engine wear. Good luck and use a torque wrench next time and you wont be faced with this dilema.
Old Feb 23, 2004 | 08:55 AM
Yamaha660R's Avatar
You could also use a magnetic drain plug. They help keep shavings and metal chips out of the engine.
Old Feb 23, 2004 | 08:44 PM
QuadFMX's Avatar
Definitely take the time and the few dollars and head to napa and pick up a magnetic drain plug. I got one after i found out my one-way had been going bad and distributing minute shavings into my case. Then 2 months later i just changed my oil today and i found the drain bolt had caught alot of em.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
tweeder
Jul 5, 2015 01:57 PM
