CDI on a warrior
Old Mar 5, 2004 | 09:27 PM
BornToRide101's Avatar
Default CDI on a warrior
I was wondering what exacley they do and how much a new one would cost for my warrior?
Old Mar 5, 2004 | 10:40 PM
dose aney one no whut they do??
Old Mar 6, 2004 | 12:03 AM
Crotts's Avatar
They are the "brain" of the quad that controls your ignition timing.
KNOWSALOT's Avatar
The Facility
It's the "brain box" for your ignition system.
What does it do? How does it work?
Way to complicated to explain in detail here, but basically, it amplifies the current from the electrical system to a higher output going to the spark plug.....enough to operate the engine. Ouput from the stator alone is not nearly enough. It also controls your engines redline limit.
How much does it cost?
It will depend on your local dealer's markup over MSRP, but the CDI has a suggested list of $296.56
If you look for one used, only the 1997-2001 models will work.
Don't try connecting one from another year or you will be looking at buying more electrical parts than a CDI
Old Mar 6, 2004 | 02:29 AM
mdkx's Avatar
First off, what makes you think the CDI went? My guess is that you do not have any spark? Troubleshoot your whole system. If you do not have any spark, first check the switch..then coil...stator...pickup ect...
Old Mar 6, 2004 | 11:42 AM
nothing's rong with it i was just wondoring whut they do. thanx 4 all the replies!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
