WHEELies
Old Mar 17, 2004 | 08:30 PM
Shav0's Avatar
Default WHEELies
i learned to wheelie going up a real small hill. its alot easier to keep it up that way and once you get it up it balances better.
Then once you get good at that go on the flat ground
Old Mar 17, 2004 | 09:14 PM
mxer250's Avatar
Default WHEELies
That helps but when u flip (if ur not to careful) it sucks. But lots of practice helps. Last summer I had a job at an atv shop so i had lots of time to ride and practice.
Old Mar 19, 2004 | 12:08 PM
BornToRide101's Avatar
Default WHEELies
i haven't hit the grab bar yet but am going 2 try it soon but will my warruio defenitoly not flib or might it flip?
thanx
Old Mar 19, 2004 | 12:19 PM
JoshCVBz's Avatar
Default WHEELies
thanx
In a perfect world it won't flip.
If you are on fairly smooth ground, and are going a fairly slow speed, you should be fine. If you aren't on smooth ground and/or you are going at a decent speed, it can flip over backwards or the grab bar can catch and tip you sideways.
As far as wheelie tips go....Staying at balance point, and smooth throttle control are key. Brake control helps too, and it's a good habit to get in, however to be honest, I mastered long distance wheelies without learing brake control first.
Practice is the best way to learn though....
I've got a few posts at our message board at www.cvboyz.com . If you take a look in there you might find some helpful info.
-Josh
Old Mar 19, 2004 | 05:18 PM
  #15
Eceriderjbomb's Avatar
Default WHEELies
Try not to pop the clutch.
Old Mar 19, 2004 | 05:38 PM
  #16
bootboss's Avatar
Default WHEELies
IMO...it isnt to easy learning to do them for ur first time on a blaster its way easier on a 4 stroke
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
black_thunder
Jul 26, 2015 09:23 PM
'86 TRX125
Jun 6, 2015 07:43 PM
dunc_n
Sport Quads
43
Nov 26, 2000 08:14 PM
