cylinder head cover needed...please help!!!
Old Mar 22, 2004 | 09:57 AM
BigScary's Avatar
Default cylinder head cover needed...please help!!!
Originally posted by: appraptor
Bartlett,
Do you think that JB weld would hold it or should I get it welded. It looks as though it is cast...steel I suppose. I am correct I believe in that this piece will not see hardly any internal pressure so I'm thinking that as long as there is a good seal, everything should be fine??? Do you have any other suggestions. This is really unfortunate and it really upsets me.
you would think that there isn't much internal pressure but there is a LOT more than I thought
I cracked the head cover where the oil line connects......(over torqued the banjo bolt)....I grinded it down and made it rough so the JB Weld would adhere properly...........
waited 48 hours and reinstalled
started the engine and oil began to squirt out of the crack and all over my head pipe.........
I ended up having to get it welded and just for good measure I put some copper adhesive on the washers and along the edge of the head cover
so far so good...........
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Bergmann
Aug 13, 2015 03:51 PM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
ltrmc02
Jul 22, 2015 04:50 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
