warrior acting funny
#26
remove the hood section, the electrical wires to the kill button or the key switch are probably about to break connection at the plug-ends. you should unplug all of them , clean them and add dielectric compound. If you stiil have the problem after that,you should use an OHM meter to check the wires individualy with the bars turned, as one or more of them may be broken inside the insulation
exmotocrosser
09-13-2019 06:12 AM
