starter help
Old Jul 24, 2000 | 10:30 PM
shockwave's Avatar
someone please help! i bought a 1988 yamaha moto 4, 350 4-stroke and it was cranking a little difficult and now will not hardly turn engine over at all! the starter is turning but only occasionally the engine will turn over. hand pull is broke but you can manually turn engine with cover off and it has compression. i cant see anything broke! what will make the starter turn but not keep engine engaged? i dont see a typical bendix but the motor acts like something is slipping when you engage the starter. the starter turns and growls but engine isnt turning? what do i check? what usually fails and causes this to happen? it was running fine and just when i tried to re-crank it will not turn the flywheel.
Old Jul 24, 2000 | 11:30 PM
Tree Farmer's Avatar
Bad one-way clutch? I'm not familiar with your machine, but experienced this failure on another.
Repair involves pulling a case cover, removing the starter mechanism, pulling the one-way clutch and repairing or replacing it. A service manual, at least an exploded parts diagram (from your dealer's microfiche) should come in handy.
The broken recoil starter results more than likely from a broken or weak spring.
Tree Farmer
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
