Reeds for Blaster
Old Jul 25, 2000 | 07:38 PM
aar0's Avatar
Which of the Boyesen reeds are the best for the Blaster, the carbon or the glass compound one's. Or does one boost one thing and the other boost another part of the band.
Thanks,
Anthony
Old Jul 26, 2000 | 12:31 PM
sAyIt_fmf's Avatar
JUst changing the reeds is a big misconseption for most riders out there.. ( don't take it wrong)
If your machine is still stock....No porting polishing...etc. Stick with the stock pedals.
The stock motor does not have enough suction to take advantage of stiffer reeds. If you have an unlimited budget...then by all means get what you want....But you won't see a difference between carbon...etc. Unless you were to change the cage also.
Old Jul 26, 2000 | 12:52 PM
DunePilot858's Avatar
As long as you get low tension reeds you will be fine... the only thing you will gain is slight throttle response compaired to stock.
Old Jul 26, 2000 | 04:06 PM
FMFBlasterMX2's Avatar
I have the regular boyeson reeds, not the carbon fiber ones, and i did notice a little better throttle response but i had put my wiseco piston in at the same time.
Old Jul 27, 2000 | 10:54 PM
blaster95's Avatar
buy carbontec reeds for your blaster boyseen reeds suck they just bow and twist
QuadRiders
Oct 22, 2015 04:13 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
