Raptor float level
Old Apr 27, 2004 | 06:06 AM
Bosch's Avatar
Default Raptor float level
I've been wrenching on my 01 660 Raptor ever since installing full FMF exhaust. 150,155 mains,middle clip on the needle,3 turns out,or so,on the air screws,and ive trimmed the fins out of the snorkle on the air box lid.The float level is 1/8th,to 1/4 inch above the mating surface of the bowl and carb body.Too high????? I'm about to pull my hair out.Idle and top end is great,,once it gets over coughing and hesitating mid range. Helllllpppppp!!!!!!!!!! Seems like i wrench on it more than i ride it.
Old Apr 27, 2004 | 06:21 AM
Ward660R's Avatar
A 1/4 inch seems too high. The perfect height is 2mm above the surface, no higher. I think at 1/4 it would be running out of your overflow tubes on the carbs...or close to it. Just a tiny little bit or height differance will make a big change, but it should affect more than mid range.
I know that didn't help much but...[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 27, 2004 | 06:25 AM
Bosch's Avatar
That did seem too high to me,,,,,just wanted to make sure before i pulled the carbs off again. By the way,,spraying W-D 40 on the boots make the carbs slide on way easy. Thanks,,,,
Old Apr 27, 2004 | 06:40 AM
Ward660R's Avatar
The WD-40 also makes them slide off easier too, which can be a bad thing. Try a little gas next time, it makes them go on quickly but evaporates quick so they won't pop off later unexpectedly.
Old Apr 27, 2004 | 07:09 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Have you checked them with a clear tube (sixsixt method)????
Old Apr 27, 2004 | 07:28 AM
Bosch's Avatar
Yes,,,,,,
Old Apr 27, 2004 | 10:05 AM
sixsixT's Avatar
Yea a 1/4" is too high, it'll usually stumble at lower RPMs when you get on it.
Old Apr 27, 2004 | 03:05 PM
FooBar's Avatar
You might want to play with the intake a little. I have a friend that started having some of the same trouble once he cut the tabs out of his snorkle, because his mains weren't big enough. To test this just put a 1-inch piece of duct tape over the snorkle. Go for a ride. Note any changes. Tear the duct tape down to a 3/4-inch piece. Go for a ride. Repeat. When all was said and done he ended up riding all weekend with a 1/2-inch piece of duct-tape blocking his intake. It worked really well. He was using the same jetting as you 150, 155. you might want to try bigger jets.
Old Apr 28, 2004 | 02:29 AM
Bing's Avatar
Super Quad Patrol
I keep a roll of electrical tape under the seat,,,,it works awesome
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
