blaster tires
so what size tire should i get. i noticed that razr doesnt have 21-10-8 so what size should i get i am only getting rear tires because my front tires are fine so i dont need info on the front only the rear thanks
the last number has to match the number of the rims size, if the stock rim is 8in, u need a tire with the last number an 8, or it wont fit. i got 20X11X8 turftamers for my blaster, and it was so wide it rubbed on the floor board thing under the peg, my only complaint. holeshots are great too.
I would go with the holeshots, then the razr's if they were not avalible. You might check out the shredder also, its not a bad tire I have been running them for a long time now and havent had any complaints about them
