Starter or solenoid?
Old May 27, 2004 | 10:56 AM
atv123's Avatar
Default Starter or solenoid?
A buddy of mine has a 2003 quad and it won't start w/ the elec. start button. The battery is fine and it will fire right up when you pull start it. When you hit the elec. start button though, you hear a clicking sound at the solenoid. How would I know if it's the starter itself or the starter solenoid? A new starter is $280 and I'm sure the solenoid is much cheaper, but didn't price it yesterday.
Old May 28, 2004 | 06:23 PM
kawasaki88man's Avatar
first check your battery power level then go to the selinoid and there should be two wires comeing out of it just put plyers across the to metal posts and if its the selinoid it will start up but if it doesnt do anything then its your starter i think its your battery thats low and the selenoid might be bad
Old May 28, 2004 | 06:45 PM
1LeSSRaptor's Avatar
Make sure you check everything really good. <ost of the tim, it's something simple, like a loose connection to the battery.
Old May 28, 2004 | 07:49 PM
atv123's Avatar
Thanks for the tips. The battery is fine, I even swapped my other quad battery in there and it had the same symptoms...
I'll check the solenoid and hope that's the problem. Will post back later.
Old May 29, 2004 | 09:36 AM
quadwrench's Avatar
Something else to check is look for a dirty starter button, sometimes the contacts will get dirty and not let the starter button switch engage fully, causing the solenoid to "buzz".
Old May 29, 2004 | 03:26 PM
atv123's Avatar
In and around the starter button looks pretty clean. I tried the plier on the starter solenoid trick and nothing happened. I guess that means it's the starter then. Bummer.
Old May 30, 2004 | 12:22 AM
quadwrench's Avatar
If you got no sparks when jumping the solenoid then the brushes in the starter are not getting contact - could be you only need a brush plate set (you can get just brushes, but unless you are a darn good solderer, it is much easier to replace the whole brush plate). Ebay has decent prices on ATV starter rebuild kits, as well as new starters ranging from $115 - $140 buy it now (not knowing what ATV you are working on) - I'd pull the starter apart before ordering parts just to make sure it is rebuildable.
Old Jun 1, 2004 | 07:24 AM
atv123's Avatar
OK - here's the deal. I tried jumping the solenoid w/ the quad on. Nothing at all, no sparks, nada. BTW - it's a 2003 Kawasaki Bayou 250. How hard is it to replace the brush plate? I'd rather do that if it's cheaper than spend the $280 on a new starter. Thanks.
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
