yamaha warrior clutch calbe problems look please
Old May 27, 2004 | 10:46 PM
RedBullGotWings's Avatar
Default yamaha warrior clutch calbe LOOK
hey i just put alot into my warrior and just got it running about 30 min ago it sounds awsome but i have a problem... the clutch cable wont recoil good like i pull in the clutch and it will go in way to easy and will come out but not all the way it will come out about 3/4 of the way and before my rebuild it was hard to pull in ... and i have the spring in correctly down by the tranny but thats the only sping i have is there another?? thanx all
Old May 28, 2004 | 10:10 AM
DS650BajaRunner's Avatar
Default yamaha warrior clutch calbe problems look please
it could be a few things
1.You need to adjust the end of the cable (where the clutch and parking brake is)
2.Cable is streched out
3.Check your parking brake im not to certain but i have been told that it gives you a hard time
Im not to familiar with the word sping but with you mean the metal end on each side of the cable there is are two of them make sure you install the other one below the clutch perch also make sure its properly installed. Hope this helps
Old May 28, 2004 | 11:02 AM
Gwinnwarrior's Avatar
the same thing happened to me this spring when i replaced the cable. there are 2 turn nuts at the end of the cable down by where it goes into the motor. those nuts have to be tightened i believe if its pulling in too loose. you just have to tweak with them until its working and shifting smoothly on both ends. hope i could help....
Old May 28, 2004 | 11:09 AM
HoundDog06's Avatar
I am not sure I understand this scenario. Are you saying that when you try to engage the clutch, the lever doesn't return to resting position (tight against the perch)? If so, I would recommend lubing your cable. I have seen clutches roasted because a filthy cable wasn't allowing the plates to fully contact. If this was not what you were explaining, could you clarify the situation please?
~HoundDog
Old May 28, 2004 | 11:24 AM
i think he means the clutch cable that is pulling in but its not recoiling back and hes wondering how hes going to adjust it thats what I understood not sure if thats the problem.
Old May 28, 2004 | 03:47 PM
ok ill try that thanx guys
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
PuhiStrain
Sep 9, 2000 01:36 PM
zuki
Mar 17, 2000 06:04 PM
dunc_n
Aug 26, 1999 09:32 PM
