Stock YFZ jetting/mods?
Old Jun 4, 2004 | 12:08 AM
Dingo2's Avatar
Default Stock YFZ jetting/mods?
My buddy just bought a new YFZ450. He was thinking that if he ran with the airbox lid off, stock pipe and K&N filter, he might gain a few HP. If he was to run this set-up, would he need to re-jet? I heard a stock YFZ runs slighlty lean from the factory, so with this increase of airflow..would he need to re-jet? We are at 1000 feet above sea level..
Old Jun 4, 2004 | 12:45 AM
ShadyRascal's Avatar
I was just running mine w/o airlid and baffle on stock jetting all weekend, but that was at the dunes at 5000' elevation. One of the guys I talked to there said on his, also stock with baffle out and lid off, he went to a 165 main jet and his home elevation is 3600. Stock main is something like 150 I think. I'd say at your elevation you should jet up, although the 4 strokes are more forgiving than a 2 stroke in this regard.
Old Jun 4, 2004 | 04:06 PM
Dingo2's Avatar
Anyone else??
Bump
Old Jun 4, 2004 | 10:43 PM
cdalepaul's Avatar
go up to a 168 main and a 45 pilot then buy the air/fuel mixture screw and then you will be able to fine tune it. this is running with no airbox and haveing the baffle removed.. p.s. if you buy a K@N filter make sure you get and outerwear for it or your engine will be toast after all the debris get through it.
Old Jun 5, 2004 | 01:11 AM
Dingo2's Avatar
What do you mean..buy an air/fuel mixture screw? A YFZ doesn't have one?
Old Jun 6, 2004 | 07:38 PM
cdalepaul's Avatar
the screw is at the bottom of the carb in front of big bolt that incloses the main and pilot jet. its a hole with a screw up in it.
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Honski250r
Sep 26, 2015 09:40 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
CosmoM
Sep 21, 2015 04:57 PM
