Going into reverse without using switch
Old Jun 21, 2004 | 09:17 PM
Tyme's Avatar
Default Going into reverse without using switch
My '02 Raptor has developed a new habit. If I shift down while in first gear it goes into reverse. I have moved the reverse switch back and forth to see if it was stuck, but it doesn't seem to affect the quads ability to go into reverse it is "always on". Any suggestions?
Old Jun 21, 2004 | 09:21 PM
sixsixT's Avatar
Check the cable down by the engine to make sure it is in the holder and the lever isn't bent. Then adjust the cable if needed.
Old Jun 21, 2004 | 09:28 PM
Tyme's Avatar
Thank you. I will go check that.
Old Jun 21, 2004 | 10:27 PM
Yamaha660R's Avatar
Mine did the samething when the cable had come out of the lever that engages reverse.
Old Jun 21, 2004 | 10:35 PM
Tyme's Avatar
I checked the cable. It is connected but has alot of play. I can push it down to the skid plate. I am assuming it should be tighter.
Njrider1230
Jul 29, 2023 05:16 AM
Reactant
Mar 30, 2022 02:08 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
ScopeZ_
Jul 28, 2015 01:44 AM
