??? raptor hotcam???
Old Jul 1, 2004 | 05:20 PM
  #21
400exKiller990's Avatar
Default ??? raptor hotcam???
then i have to have them out in right? i cant do that myself can i?
Old Jul 1, 2004 | 05:42 PM
  #22
is there any way to thorghly clean the in side of my motor?
Old Jul 1, 2004 | 06:08 PM
  #23
warwgn's Avatar
intake valves are $17.00 each for stock, not sure what exhaust run, ??
Old Jul 1, 2004 | 08:51 PM
  #24
UBETRUN's Avatar
You can flush it a couple of times but there is no guarantee that you'll get every bit of metal out of the bearings and oil passages. Fill it with kerosene a few times and see how much crud washes out. You may be OK but there is only one way to find out, put it all back together and ride it. Worst case, you'll have to rebuild the motor anyhow.
Old Jul 7, 2004 | 01:58 AM
  #25
[quote]
how can i fill it with kerosene with the head and flywheel off?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 7, 2004 | 01:59 AM
  #26
or if i put it back together how would i fill it?
Old Jul 7, 2004 | 02:21 PM
  #27
aanyone?
Old Jul 7, 2004 | 02:30 PM
  #28
warwgn's Avatar
put the side cover on and if the head is off just pour it down the passage for the cam chain, then drain it, next fill as much as you can through the oil tank, then do the case again and that will get alot of gunk out.
Old Jul 7, 2004 | 03:31 PM
  #29
how can i make sure it gets in everything? like on the right side of the motor im sure i will miss places
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
