??? raptor hotcam???
Old 06-22-2004, 02:08 AM
400exKiller990's Avatar
Default ??? raptor hotcam???
just put a stage 1 hotcam in my raptor and was wondering if it is normal for the motor to be noisier?? it seems the valve train is making the noise... thanks
Old 06-22-2004, 04:04 AM
Yamaha660R's Avatar
my valve's are nosier with the stage 2 cam. so hasn't about everyone else's that i have asked. seems to be normal.
Old 06-22-2004, 04:25 AM
so hasnt what?
Old 06-22-2004, 10:56 AM
maddog56's Avatar
I have a stage one on a stock bore engine. The valves will be a little noisier, but not too much. Check your decompression pin and the valve lashes.
Old 06-22-2004, 11:04 AM
decompression pin? is that on the cam sprocket? how do you check it? valves r good.
thanks.
Old 06-22-2004, 07:09 PM
maddog56's Avatar
Valves need to be set according to hc specs. .2 and .25 I think. Around 8 and 11 thousandths but dont take my word for it.
The decomp pin is in the body of the cam. If you installed the cam, you should have put one in. Its on a little spring and is used to release compression while starting the bike. Make sure it is not stuck in or out, most importantly out. HC is notorious for problems with the decomp pin. If you have to, you can use the stocker or take it out all together.
Old 06-24-2004, 08:28 AM
deltadawg's Avatar
Now that you mention stuck decompression pin, mine is a beeootch to turn over. I bet it's not working.
Old 06-24-2004, 10:31 AM
CaptBags's Avatar
Any cam with higher lift and, longer durations (which performance cams have) is going to make the Valvetrain more noisy!
Old 06-24-2004, 10:54 AM
raptornuts's Avatar
Did you keep stock compression ? And how big power gain you feel ? I'm thinking about stage 1 for my raptor, but somewhere I read that without higher compression piston, gain is not so great.
rnuts
Old 06-24-2004, 12:28 PM
CaptBags's Avatar
I'd say you'd feel more from porting in addition to the cam than you would from the higher comp piston. But all 3 is the way to go!
Quick Reply: ??? raptor hotcam???
