Warrior Carb Needle...
Old 07-01-2004, 03:29 PM
ryangibson's Avatar
Default Warrior Carb Needle...
I tried playing with the mixture screw a bit, but didn't notice a lot of change either way. I'll go back in there and tweak with it a little more though.
It's really hard to get to, do you have any techniques for turning that screw? I had to go buy a 3" flat bladed screw driver, and cut about 3/4" of the handle off, and it just barely fits.... How far can I safely unscrew it? I think it's about 3 turns out now...and I never heard the RPM's drop on the way back out, so I just left it there. Sounds like my pilot jet is a little too lean eh?
I don't know about that gasket, I'll check it out though.
Old 07-01-2004, 04:19 PM
hondabuster's Avatar
You can get a #4 flat blade bit, from home depot, and should be able to turn it with just your fingers. Sears has a small knurled holder for 1/4" bits, if you need more leverage or something easier to turn.
If you keep going out, the screw will eventually come completely out. If you get to 4 turns out, from seated, and it still hasnt dropped rpm, then thats enough to know your too lean on the pilot.
Old 07-01-2004, 05:10 PM
ryangibson's Avatar
Thanks, I'll give it a try!
Reactant
03-30-2022 02:08 AM
GregM
03-06-2018 06:53 AM
GregM
07-29-2015 09:41 PM
Aitch
07-21-2015 09:40 PM
Reactant
07-16-2015 10:29 PM
Quick Reply: Warrior Carb Needle...
