wolverine problems????
Old Jul 20, 2004 | 02:19 AM
  #21
aintnostoppinme1's Avatar
Default wolverine problems????
alright im gunna call the dude tomorrow...
Old Jul 20, 2004 | 03:26 AM
  #22
Blaster96's Avatar
Let us know what happens. Besure to get the history of the quad.
Old Jul 20, 2004 | 01:22 PM
  #23
what should i ask him about it
Old Jul 20, 2004 | 02:26 PM
  #24
and what should i look for when i go to see it?
Old Jul 20, 2004 | 03:51 PM
  #25
Blaster96's Avatar
I would offer him 2,900, but do not pay more than 3,250 for it.
This is my quad checklist:
~Plastic:
*Look for scratches
*Check for stress marks
~Lift font end:
*Check the front bearings
*Inspect under the font Diff
*Make sure the CV boots are not torn
*Check A-Arms
*See how much play is in the steering wheel
*Bent/streesed Tie Rod and tie rod ends
~Wheels and tires:
*Check for puncures in the sidewall
*Dents in the wheels (allong bead)
*Is it missing those black "YAMAHA" caps in the center of the wheels
~Rear end:
*Lift each back tire a little to check for worn out rear bearings
*Is the Axle tube bent
*Drive Shaft boot torn or not
*Brake rotor; is it pitted
~Engine:
*Check the pull cord
*Check the oil
*Any oil stains on the engien cases
*Rock rash on the underside of the cases
*Air Filter, check the filter and box
*Start it up, and get it good and warm
-Listen for piston slap or worn out rod (valve noise is comon on these quads)
-Is it blowing any smoke?
-How is the idle and throttle responce
RIDE THE MACHINE!!! Do not pay a dime on it unless you can ride it around.
~When you ride:
*Check the brakes
*Hit the gas once, do you hear clanking
*Mash the brakes, do you hear clanking
*Turn sharply to the left and right, any funny noises or jerking
*Back up
*Run through the gears
*How well does it shift?
Old Jul 20, 2004 | 08:17 PM
  #26
RoscoePW's Avatar
try and convince the guy it needs some bs it doesnt to save a few hundred, might work
Old Jul 20, 2004 | 11:29 PM
  #27
i talked to him today... he said 3000 is the least he will take i think i will offer him 2800. if he wants more 2850 is the highest i might go unless its really good which it looks like in the pic. i am going to look at it saturday. anything else i should look for?
Old Jul 24, 2004 | 08:55 PM
  #28
i went and looked at it today it rode good and all but me and my dad were checking it out and it had an oil leak coming from the transmition so as soon as we saw that we left... so i am still looking....
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
