HP & Speed
Old Sep 30, 2004 | 01:22 PM
FMF's Avatar
FMF
Default HP & Speed
Ok what does my Banshee have for HP & Speed it has.
Passion 12 Prot Stroker Kit
Cool Head w/21cc Doms
28mm Flat Side Carbs
V-Force Delat 2s
Boost Bottle
FMF Fatty Pipes
Power Core 2s
Team Alba Clutch kit
Hinson Clutch Basket
Hinson Cushions
Hinson Pressure Plate
Lightened Flywheel
Vitos Degree key
Pro Flow Intake
6 Filtered air Vents
15/41 Gearing
Old Sep 30, 2004 | 04:17 PM
Jibrille's Avatar
Default HP & Speed
Put it on a Dyno. No one is going to be able to tell you jack here.
Old Sep 30, 2004 | 04:29 PM
Bradracer18's Avatar
Default HP & Speed
From what I can tell, I would say about 46hp, and 82mph........ok actually I have no idea....do as he says^^^^
Old Sep 30, 2004 | 06:05 PM
roosthrower's Avatar
Default HP & Speed
since when did you get your cylinders ported by passion racing? less than a week ago you said you had race logic templates port job. quit screwing around man. it's annoying the hell out of me.
Old Sep 30, 2004 | 06:18 PM
FMF's Avatar
FMF
Default HP & Speed
I do not have the Passion 12 Port Stroker Kit yet. I am getting it over the winter and was just trying to Find out how Much HP I will have and what will my Top Speed be.
Old Sep 30, 2004 | 06:31 PM
JakalWarrior's Avatar
Default HP & Speed
Top speed? what does hp have to do with top speed? Gearing alone decides as long as you have enough hp to pull the gears and im sure you can find an online calculator to figure it up.
Old Sep 30, 2004 | 09:54 PM
sredish's Avatar
Default HP & Speed
I have a Patriot 12 Port crank with short rods and a long crank. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 30, 2004 | 10:16 PM
Shav0's Avatar
Default HP & Speed
Chill out dude. I think you should take your ***** outta the vice, it's annoying the hell out of me.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
