Once again Wolverine, scrambler500
Old 11-21-2004, 12:20 PM
OffRder15's Avatar
Default Once again Wolverine, scrambler500
Originally posted by 1ShotScott
you know whats kind of funny the wolverine owners coud buy the warn 424 and the locker for the front diff a good $200 exhaust like the HMF utility series and a new set of tires and would finaly spend as much you guys with the scram.
That would be silly. Why wouldn't you just get the Scrambler then?
Personally, I think there is no way a Wolverine is better in the snow. The only low part of the Scrambler is the sprocket and the rotor, which both cut their way right through. Plus, the Scrambler just has more power. Was it mentioned that it has true AWD?[img]i/expressions/face-icon-small-wink.gif[/img]
  #92
Old 11-21-2004, 12:48 PM
LotusPosition's Avatar
As soon as they lose the chain drive, belt drive, macpherson struts, single lever brakes, auto trans, and 100 lbs, I will be first in line. [img]i/expressions/face-icon-small-wink.gif[/img]
Why do you guys think for one minute that a 350cc bike will be faster than a 500? Anyone comparing the Scrammy power to a 650 Prairie ? Didn't think so. Apples and oranges.
  #93
Old 11-21-2004, 01:26 PM
LLL's Avatar
LLL
LLL is offline
The scrambler goes much, much better in snow and a little better in the mud than the wolverine. The only place the scrambler has less ground clearance is at the sprocket but it still goes better. Like I said before they are both good just different.
  #94
Old 11-21-2004, 05:28 PM
Gopher500's Avatar
ive raced a prarie 650 twice now...and i won both times.....
the reason we compare em is cuz the 350 is also 100lbs lighter than the 500.
  #95
Old 11-21-2004, 06:52 PM
Uhhhh, if I was on the 650 and lost, I would go find out what was wrong with my bike.
  #96
Old 11-21-2004, 07:05 PM
BigBaller's Avatar
You shouldnt even compare a scrambler to a p650, The scrambler is about 5mph faster then the wolverine speeding at 65. Wolverine stock can hit 58-60. A nicley modded wolverine can beat a stock scrambler. The scrambler may be a little faster. But it will hit that top speed of 65 alot faster then the wolverine.
  #97
Old 11-21-2004, 07:26 PM
Gopher500's Avatar
uh.......
a scrambler is known to be right around equal with a prarie 650, and tend to be a lil quicker but less top end....i raced a stock prarie 650 and mines just about stock except for the k&n air filter.
  #98
Old 11-21-2004, 11:50 PM
fudmucker's Avatar
not to be rude or anything but bopher i dont think u not wut ur tlking about. if ur scrambler can beat a 650 parire with only a k@n air filter in it then u must of baught a one of a kind scrambler let me tell yeah. the one thing polaris sux at is weight. at weight will slow u down.the scrambler weighs around 550-600 lbs if im correct the praire weighs in the mid range of 600 close to 700. the praire also has 150 more ccs in it then that scrambler. im sry but i just dont see any polaris other then the predator beating the praire 650 in a rcae
  #99
Old 11-22-2004, 01:08 AM
Bradracer18's Avatar
How about the 400 2 stroke????
  #100
Old 11-22-2004, 09:22 AM
1ShotScott's Avatar
I could beleive that a 400 2 stroke could beat a 650 especily if the 2 stroke has mods.
Quick Reply: Once again Wolverine, scrambler500
