What Kind of Grease?
Old Oct 19, 2004 | 11:58 AM
Secondlook's Avatar
Default What Kind of Grease?
maybe someone can help me, I have kept my zerks all greased since owning my '02. Can't get it to stop squeeking WTF? can anyone help?
Old Oct 19, 2004 | 01:31 PM
30Bones's Avatar
I have been running Lucas that you can get at any parts house. 3-4 bucks a tube. I usualy grease AFTER every trip to get the muck out that might get in., then it's ready for the next ride.
Secondlook if you are hitting all six up front and all 3 out back, then I'd imagine you need to replace the bushings/bearings. Mine squeek if I skip a greasing. I plan to tear it down over the winter and replace all of them though.
Old Oct 19, 2004 | 03:03 PM
Lightman's Avatar
Lowend - I think you'll find this really helpful. All greases are not the same.
http://www.bobistheoilguy.com/GREASE/index.htm
Old Oct 19, 2004 | 03:12 PM
Lowend5's Avatar
And to think I thought grease was just grease...
Thanks for the Grease101 course....
E
Old Oct 19, 2004 | 03:41 PM
  #15
Lightman's Avatar
Lowend - check this text out I just got while browsing valvoline's site. I was just curious after reading the 'grease 101' today what exactly it was. Looks like the Synpower grease is lithium based, with synthetic additives etc. Probably a good fit.
"SynPower Synthetic Grease is an excellent heavy-duty and multi-purpose automotive and industrial extreme-pressure grease. SynPower is formulated with a lithium complex thickened in a synthetic base oil, moly and other premium additives to provide superior protection from high loads and extreme temperatures.
Provides superior high- and low-temperature protection (-60°F to 425°F) over conventional greases
Exceptional resistance to heavy loads
Moly-fortified for increased film strength
Extreme pressure fortified
Inhibits rust and oxidation
NLGI #2 GC-LB lithium complex EP grease"
Old Oct 19, 2004 | 04:01 PM
  #16
Lowend5's Avatar
Yeah... I saw this yesterday when trying to edumicate myself about grease....
I am going to check it out...
Hey! any more "grease" threads and you're gunna need to change your name from "lightman" to "the greaseman" - Hee Hee
Thanks for the info!
E
Old Oct 19, 2004 | 09:53 PM
  #17
Boxhead's Avatar
Hey second, if the squeak is coming from the swingarm it's probably the swingarm pivot bearings, you'll need to disassemble the swingarm and put red bearing grease on the bearings and around some other components in there. It usually needs to be done every 2 to 3 years for rec riding. While your at it you should put some on the front wheel bearings and steering stem bearing as well. The dealerships/factories tend to leave them slightly dry. Unfortunately I have to rebuild/maintenance mine as well.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
