Problem with 05 IRS Kodiak 450's
Old Nov 17, 2004 | 09:55 AM
  #101
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Default Problem with 05 IRS Kodiak 450's
Thanks guys, I'll let you know how it comes out. I will contact a yamaha dealer near here then I will call yamaha. As the saying goes "The squeakie wheel gets greased"[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 17, 2004 | 12:48 PM
  #102
zsebi's Avatar
Originally posted by: rlac
Kodiak....you can call (800) 962-7926
I have to wait till the weekend to get mine out for a test run with the new pads.
The squeal was very annoying. I did not baby mine either. The Grizzly does not have a rear disc. Why they put one on the Kodiak is hard to understand.
the disk brake is the best thing to have on an ATv,
drum brake must be adjusted correctly all the time to give good performance, it is less effective, harder to clean , replace or to inspect.
I had drums all around on my honda rancher , I hated it.
the drums brakes on my honda rubicon got oil on it repeatedly on a so called sealed system, and had poor braking performance because of it. I kept cleaning and cleaning then sold the machine (not because of that reason )
I'll take the disc any day over the drum , even if it squeeks.
Old Nov 17, 2004 | 06:55 PM
  #103
Lightman's Avatar
It's all about the kawasaki wet sealed rear brake. Disc scmisk [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 17, 2004 | 08:29 PM
  #104
zsebi's Avatar
I am begining to think that all that squeking- mambo jumbo -may have to do with that paper thin brake disk yamaha put in the back .
I hope they will come out with a recall
Old Nov 17, 2004 | 09:35 PM
  #105
Lightman's Avatar
It really sound like the caliper is not fully releasing the pad from the rotor, and they are slightly dragging.
Old Nov 18, 2004 | 08:59 AM
  #106
MiseryMachine's Avatar
On my machine i got a little dirt and sand on the caliper itself, and it seems to move a little slower than usual.... it requires and extra little help to release from the rotor. Now, i took it off cleaned it up as much as i could, then put it back together, and it hasn't squeaked for a while, until it got a little dirty again.... then it seems to stick... i cleaned my pads, and there is no dirt in there, and it still seems to squeak.
Old Nov 18, 2004 | 10:27 AM
  #107
rlac's Avatar
Well....the new softer pads did not work....after I went through some water and sand/mud the squeal comes back...it almost sounds like the rotor is warped. Does this sound familiar to everyone else? I think I will ride thru the weekend and take it back on Monday.
Old Nov 18, 2004 | 10:30 AM
  #108
dmger14's Avatar
I wonder if we can start a petition to Yamaha explaining the problem we all have and asking them to recall them? Mine hasn't been bad yet, but any such noise shouldn't be expected or tolerated!
Old Nov 18, 2004 | 11:05 AM
  #109
I'm calling this Morning and all other should call too 1-800-962-7962. Let's raise alittle hell![img]i/expressions/face-icon-small-mad.gif[/img]
Old Nov 18, 2004 | 11:21 AM
  #110
Lightman's Avatar
Now that you guys mention it, my squeal noise started the second I crossed my first creek with the quad...
