Problem with 05 IRS Kodiak 450's
#51
Z, thanks for the help. Any chance you could snap a pic of the front grease points? I can't seem to spot them, I've only covered the 4 rear.
As for the assorted zerk package - I got a 90 degree metric set and the threads were correct. The problem was once tightened they pointed in a direction that was inaccessible. Maybe with a washer they would point the right way but I was worried about sealing if there was a washer there.
#52
there is 4 fitting all together on the rear suspension, 2 on each side
and 2 fitting on the rear drive shaft (1 at each U joint) this is the shaft from the engine/trans to the rear diff housing.
and 2 at the front drive shaft........ same place at the U joints.
8 grease fitting on the whole ATV.
I will recheck on those metric zerks, may be there is different sizes available, wish they would standardize these things.
thanks for the confirming that it is metric.
there is a picture of the driveshaft fitting in my previous post (few post up)
#54
there is 2 different needle I have seen in the stores,
the one use is aprx 1/8-3/16 inch diam. and screws on to the end of the gun hose, it has a tapered end which will push the littlle ball at the end of the zerk fitting , the taper will act as a seal .
the other kind I have seen is like an actual needle (thin) , same as the one the doctor would stick you with.
this is the one you would use if you want to inject grease in to a rubber boot ( which I would not reccomend)
this slim needle I can not see usefull for zerks since the needle would push in the ball at the top of the zerk , but woulnot seal it as you pump grease so grease would just end up on the outside of the fitting.
#56
you should be able to buy the 90 degree grease gun attachment and the needle attachments at most autoparts stores or where they sell tools,
example, I got the 90 degree fitting at---- Autozone----, and got needle at ----carquest --- awhile back before I even had the kodiak.
I would think if you have tool stores like ---sears-- , or---- farm and fleet---- ,or--- tractor supply --- to name a few these guys all sell tool and surely will have grease guns and attachments.
good luck
good luck
#57
Dmger, happy to give a little back to a forum that's helped me a lot. The needle fittings were available everywhere I went, you shouldn't have a problem. I need to pick one up myself, and try to get at the front zerks.
#58
just a line about those squeaks- you can check my post "2003 kodiak 400 problems (worst purchase ever) LEMON"
never really got an answer on the fix they finally gave me a new kodiak because they rolled it during a "test" drive. my guess is that when they are being assembled some thing is getting screwed up b/c they seem to have this problem from the start or they're fine.
