New! Valvoline ATV 4 Stroke Oil...
Well I was out and about today picking up some new tools to tinker on the Raptor with, and while I was looking around I found Valvoline ATV 4 Stroke Oil. I got to reading on the label and it seemed to be a pretty good oil.
Valvoline Provides:
*Extreme Condition Performance: Thermally-stable formula maintains proper lubrication to protect engines under extreme conditions.
*Wet Clutch Protection: Optimal frictional characteristics for high torque, smooth shifting and proper protection of the wet clutch.
*Corrosion Resistance: Advanced additives help protect against water, depostis and other corrosive materials to keep engines clean.
*Maximum Horsepower: Proper additive balence for maximum horsepower.
*Minimal Wear: Increased anti-wear agents minimize wear from metal to metal contact.
*Shear Stability: Shear stable viscosity improvers better resist oil film breakdown.
Meets or Exceeds Manufacturer's Warrenty Requirements.
Using this Product will not void manufacturer Warranties.
Seemed like a pretty good oil, and was only $2.59 a qt. So I picked up enough to change the oil in the Raptor. Anyone have experience or see any reason this wouldln't be a good oil to run in a High Compression, High Horsepower, High Torque, Raptor?
Valvoline Provides:
Its been out for a few years. That what Ive been running. BUT I run the motorcycle oil 4-stroke Valvoline. Kinda the same. "suprior wet clutch protection" I have ran the atv oil also. Its good stuff and cheap. I usually run 20/50 and I just switched to 10/40.
On the top of the label it says...
"High Temperature Performance"
"Superior Wet Cltuch Protection"
I guess the "NEW" logo's were because it was new to the NAPA I was in. LOL. Well it's good to know that someone else with a built motor has been running it. I picked up 10w40 as well.
Valvoline ATV Oil is the only oil I"ve been using for the past 2 years. Its never failed me, so I'm a believer!!![img]i/expressions/face-icon-small-smile.gif[/img]
The only problem is, its hard to find...[img]i/expressions/face-icon-small-mad.gif[/img] I just hit all the Autozones and Kragan Auto Parts stores in my area every other month and buy all they have. I've got a stockpile of 5 1/2 cases in the shop, so that should last me a couple months...[img]i/expressions/face-icon-small-smile.gif[/img]
i am currently using this full synthetic Bardahl Snowmobile Racing oil than i bought for $20 a litre [img]i/expressions/face-icon-small-confused.gif[/img] and my YFZ seems to like it. However this isthe hardest oil to find and have only saw it once in one place. Also is the Valvoline oil fully synthetic, if not i will not even bother..
Ozark38, Mobil1 mx4t made your clutch slip??? I've been using it in my Kodiak and have noticed no problems. Isint it designed for wet clutchs and made for 4 stroke atv's? Everything I have read says it's the oil to use as far as wet clutch's and no friction modifiers?
Are you sure???
Are you sure???
exmotocrosser
09-13-2019 06:12 AM
BYC
09-25-2015 02:10 PM
Quadzilla Heritage
09-25-2015 01:39 PM
