Blaster Help
Old Dec 30, 2004 | 01:33 AM
blaster2002004's Avatar
Default Blaster Help
I recently blew a piston in my 2004 Blaster for the 2nd time and this time it burnt up a gasket which allowed oil to go into the entire crank case. Instead of fixing it for 350 bucks or so My friend was selling his 2002 blaster engine with a bills pipe and silencor. And when im riding it now it feels like the 1st 2nd and 3rd gears are very "close" together feeling. like its catches each gear quicker.. Is that because of the pipe and silencor or is it just different for each qaud? Is there any way i can get those gears spaced out more? cause it seems like it revs it up too high each time.
Old Dec 30, 2004 | 01:50 AM
FdaDOT200's Avatar
you could gear it differently?
Old Dec 30, 2004 | 11:24 AM
How do you do that......I drilled a bunch of holes in my air lid and it seems to work better. and it doesnt rev out as fast. But i have another problem but its a not a big one. when im riding in like 6th gear and i pull in the clutch to turn or stop it still revs kinda high? any ideas?
Old Dec 30, 2004 | 01:51 PM
mad4racing's Avatar
chack your valves and jets that the only thing i can think of.
Old Dec 30, 2004 | 01:55 PM
Shav0's Avatar
If you drilled holes in your air box and didn't change your jetting then you can count on burning up that engine just as quick as the last one.
Old Dec 31, 2004 | 12:43 AM
What should I change my jetting too??? the Temp is also between 20 and 40.
Old Dec 31, 2004 | 08:39 AM
Shav0's Avatar
Depends on where you at now. But you can't add that much more air flow without increasing the gas mix along with it. Your creating a very lean condition that will burn that piston up in no time.
Old Dec 31, 2004 | 12:12 PM
NBake's Avatar
u could do a plug check to see where ur jettings at. but i guess its a pain in the *** to get to the plug huh?
Old Jan 3, 2005 | 10:30 PM
No, its pretty easy. I took the carb out and took a look at the jet and its a 230. So my friend said int he cold weather go up ten so im gonna put a 240 in it and it should run fine.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
