Use Choke Insted Of re-jet?
Old 01-16-2005, 02:03 PM
86LT250RFatty's Avatar
Default Use Choke Insted Of re-jet?
Hey. I recently took my baffle out of my muffler on my 660R, and now its running pretty lean, not to mention the 30 Degree tempature. I noticed it revs smother with the choke 1/2 way on, then with it off. Could i just keep the choke 1/2 way on, and adjust the idle back down to normal? And keep riding like that? Because im getting a full exhaust soon, and i want Wait untill i get it to completly Re-Jet. thanks for imput.
Old 01-16-2005, 02:23 PM
also, where is the Piolit Screew on the carb??? I cant find it, i want to also try turning the piolit screew out a turn. thanks.
Old 01-16-2005, 03:11 PM
Shav0's Avatar
Now that is ultimate lazyness.
In theory it works, but I wouldn't suggest doing so. Just bump the main up one size and turn the screw to get the idle set right.
Old 01-16-2005, 03:17 PM
yo, its really hard to re-jet on a raptor, you have to remove all the plastics, gas tank, air box, battery...on my LT it took 15 min to re-jet this is different. Does anyone know where the piolit screew is on the carb?
Old 01-16-2005, 03:28 PM
TrailBlazerguy250's Avatar
My firend and i rejeted his raptor in 20 mins and only had to take the tank off, just unbolted it from the motor
Old 01-16-2005, 03:29 PM
hondabuster's Avatar
alba
Its #23, in front of the float bowl on the underside.
Theorericly using the choke (enrichener circuit) is the same as going slightly richer on all circuits. It doesnt restrict air flow, there isnt any harm in doing this, and its preferable to doing nothing and running lean.
Old 01-16-2005, 03:53 PM
Originally posted by: hondabuster
alba
thanks man, just what i wanted to hear! thanks for all the imput guys.
Old 01-16-2005, 04:26 PM
YamahaAtvFreak's Avatar
Choke it Biatch
Old 01-16-2005, 04:51 PM
thewayout420's Avatar
if you arent ready to rejet,then maybe you should put the baffle back in..it seems pretty stupid to take the risk of running lean and blowing your engine..
Old 01-16-2005, 04:54 PM
BURKEDADDY's Avatar
why do you have to take your battery out to rejet?never heard that before.just take the gas tank off thats the way they did it at the dealership when i took it in stood and watched for 4 hours and they still didnt get it tuned it right.
Quick Reply: Use Choke Insted Of re-jet?
