how do i readjust floats on 2001 Yam Warrior??
Old Jan 21, 2005 | 06:48 PM
NJatvRider96's Avatar
Default how do i readjust floats on 2001 Yam Warrior??
I need to know how to readjust the floats on my 2001 yamaha warrior. while i was in the process of cleaning the entire carb, i think the float timing got messed up because the quad isnt idling right and im afraid to ride it cuz i dont wanna mess anything up. if anyone knows how to readjust the floats can you PLEASE tell me because ill do it in the morning before we get hit with the snow storm so i cna get out and ride..
thanks so much
jeff
Old Jan 21, 2005 | 10:33 PM
95wolv's Avatar
To set the float, take the bowl off, flip the carb upside down, and check the float height at the line or ridge in the middle of the float. Set it between 11 - 13 mm. Adjust the level by gently bending the little metal tab that rest on the needle and seat, until you get the right level. Reinstall, and you should be set, but while the carb is apart, take the time to spray out the carb real good, might as well clean it up good while it is out.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
wrencher82
Sep 24, 2015 03:39 PM
