unclear on tire size need help
Old Feb 1, 2005 | 06:19 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default unclear on tire size need help
i run 22" holeshot xtc 6-ply,,,,and 23" in the front
i hit my skidplate maybe 20% as much as i used to
drop a tooth on the front sprocket,,,,,and add a couple in the rear
joila!!! You will like it
Old Feb 1, 2005 | 06:55 PM
MasterRaptor's Avatar
I run 22" on the front and back. I recommend it on the trail and rocks. You get a better ride, more top speed and ground clearance. I am running RAZR2 and they are tuff and light weight and hook up like a dream.
You will want to add wheel spacers to the rear to widen the axle. I noticed added tippyness going to taller tires. Wider back will take care of it.
Old Feb 1, 2005 | 07:10 PM
bansheemike's Avatar
to save money.. flip your rims.. does the same job and you don't lose any strength.. I race motocross with flipped rims and a durablue axle and its very stable..
Old Feb 1, 2005 | 09:28 PM
Raptors handle terrible with flipped front rims...espessially on rocky or rutty terain.
Old Feb 2, 2005 | 11:22 AM
  #15
maddog56's Avatar
Originally posted by: bansheemike
if you want more speed throw a smaller sprocket on the back.. the bigger the tires the hard your clutch works. my friend had 22 inch pure sport realtors and they are pretty heavy.. bike was 3 months old and he blew the clutch out..
No, you dont put a smaller sprocket on the back, you put a bigger one on the back or a 12 tooth on the front.
Old Feb 2, 2005 | 11:41 AM
  #16
for more speed.. bigger on front smaller on rear...
Old Feb 2, 2005 | 11:49 AM
  #17
maddog56's Avatar
You arent looking for more speed, the taller tires give you that already. To get the gear ratio back to what it was before the tires you need to get a bigger rear or smaller front. Besides, you would want more low end grunt to get the tires rolling.
Its no wonder your buddy fried his clutch if he went to a lower gear ratio AND got bigger tires without the motor to turn them at that gearing.
Old Feb 2, 2005 | 02:01 PM
  #18
Bing's Avatar
Super Quad Patrol
Originally posted by: MasterRaptorYou will want to add wheel spacers to the rear to widen the axle. I noticed added tippyness going to taller tires. Wider back will take care of it.
my tires cam on +1 offset douglas .190 front and back
I like it,,,,,,,,,except for the slight increase in bump/steer
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
