Raptor vs yfz450
Old Mar 8, 2005 | 07:45 PM
  #31
stang00's Avatar
Default Raptor vs yfz450
what are the dangers of running a 11.1 compression piston and a stage 1 cam?
Old Mar 8, 2005 | 07:53 PM
  #32
Rider1169's Avatar
You not putting the motor together properly. Those are mild mods, Right? No damage done unless its put together improterly.
Old Mar 9, 2005 | 01:38 AM
  #33
Froooo's Avatar
Just wondering, why would anyone buy a 2004 Raptor(which uses a motor from some dual-sport bike Yamaha sells in Europe..hence the crappy shifter linkage) & then hop it up with cams, pipe, filter,etc...when you could have bought a 2004 YFZ 450? Is it because it has reverse? Or was it the 660 sticker on the side of it?
Old Mar 9, 2005 | 01:42 AM
  #34
stang00's Avatar
i ride alot of trails and i need reverse ... oh and its a 2005 not 2004
Old Mar 9, 2005 | 01:58 AM
  #35
Froooo's Avatar
I was talking about rider1169....
Old Mar 9, 2005 | 02:17 AM
  #36
maddog56's Avatar
Reverse and a more comfortable ride. Not to mention much more potential and better power per dollar. Better trail machine IMO too.
Some people like the yfz, some like the raptor. God forbid some people even like both (me). Not everyone has to ride the same machine to have a good time, and no single machine is always faster than others.
Old Mar 9, 2005 | 10:41 PM
  #37
stang00's Avatar
well fro i really dont know why you critize a raptor ... have you ever even ridden one i notice you dont have any atv's in you sig...
Old Mar 9, 2005 | 11:10 PM
  #38
Froooo's Avatar
Stang, all I'm saying is that if you're gonna spend money on cams, pipes, etc to hop a Raptor up you could have saved money by buying the YFZ 450 in the 1st place. Pipes & cams would run you at least $700, not counting labor to install the cams(unless your sure enough of yourself to do it yourself),then after you have the Raptor running like a striped ape you still have to address the narrow stance of the machine with aftermarket A-arms, shocks & a wider axle & then add at least a grand for those items.Sure, the Raptor is a great quad, but if you really want performance, get the 450...it's cheaper if you think about it. Oh, just because I didn't list my quads & bikes doesn't mean they don't exist.
Old Mar 9, 2005 | 11:17 PM
  #39
stang00's Avatar
a raptor has more potential than a 450... i cant leave anything i have stock and i got the raptor at a good price so with all the installs im doing it puts it at the price i could get a 450 for... but my raptor will kill a 450... so it wouldnt save me money buying one
Old Mar 9, 2005 | 11:33 PM
  #40
Froooo's Avatar
A Raptor has more potential than a YFZ 450?? Are you kidding? You must be talking about hopping up the motor since the 450 already has higher compression & revs further then the 660. Or are you talking about making it a full on drag bike?Sure, it takes more work to get a Raptor to run like a 450..so I guess you can call that having more potential motor work to do. You do know that you can send the 450's head out to Pro Circuit & have it flowed & ported & also bump up the compression too. Don't even say that the Raptor's swingarm, shocks & frame have more potential, & I haven't even mentioned the weight issue yet! More potential work to get it to perform is what I see.
