2003 Wolverine problems???
Old Mar 29, 2005 | 11:31 PM
LimeGreenCat's Avatar
Default 2003 Wolverine problems???
My buddy has a 2003 Wolverine he just got used. Well we unloaded off the truck today and start it up and it starts up fine but whenever you give it gas it just starts backfiring ans sputtering. But if you just start driving it around it will go away and then sometimes it will come back when you lay off the gas it will come back and start sputtering and backfiring but then again sometimes it won't. I think it is also shooting gas into the air filter but am not sure. I think there is also gas in the oil. I was thinking it is either water in the tank or the float needle is stuck becasue it has been sitting for awhile but am not sure so tommorrow I am gonna drain the gas and get some more and put heat in it and if that doesn't help I guess get the carb rebuilt but I was wondering if thier was anything else I can try before getting the carb rebuilt?
Old Mar 30, 2005 | 07:12 AM
LotusPosition's Avatar
Drop the float bowl on the carb, it is not unusual for there to be a big piece of dirt in there. An inline fuel filter will combat this problem.
If that does not do it, try wiggling the little switch on the emergency brake lever. Sometimes they stick, leaving the parking brake rev limiter on, causing an acceleration misfire.
Old Mar 30, 2005 | 06:00 PM
Roach007's Avatar
I agree with LOTUS on the emergency switch, my old Wolverine used to do it all the time......
Old Mar 30, 2005 | 08:11 PM
Sparks89's Avatar
I took the parking brake completely off about 5 years ago.
Old Mar 30, 2005 | 09:19 PM
Cab00se's Avatar
yeah i had the same problem...since the E brake doesnt work right on mine and my dad put it on when haluing it to my friend's house i fogot it was on and my wolvy started sputtering but then i realized E brake was on =p silly of me....
Old Mar 31, 2005 | 06:58 PM
DaChief's Avatar
I just got my Wolverine last week. Yesterday I adjusted the parking brake so it would hold. I thought it was sputtering because I forgot to turn the fuel valve, but I guess that wasn't it. Good to find the truth!!!!!
Joe
Jmuddin284
Jan 19, 2026 07:16 AM
Captjay
Jul 23, 2015 12:33 PM
95wolv
Jul 17, 2015 08:13 PM
steveo612
Jul 11, 2015 08:35 AM
Chocobamofo
Jul 10, 2015 07:46 PM
