Warrior Power?
Old Apr 6, 2005 | 07:01 PM
YBlasterboy's Avatar
Default Warrior Power?
If i took out the spark arrestor and took off the air box lid, would it give me any more power.Also, what is that thing on the air box lid, its like a cable and it connects to the part of the air box that goes under the gas tank.
Old Apr 6, 2005 | 07:12 PM
bberck's Avatar
Probally some but probally make you run lean which isnt good. I guess your referring to the crankcase breather hose only thing on mine up there
Old Apr 6, 2005 | 07:21 PM
Ya, i looked it up it is the breather.Also my pipe was glowing last night is it running to lean.(i didnt have the lid off or the spark arrestor out) is that normal?
Old Apr 6, 2005 | 07:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
GLOWING red is lean... or rich... i think it can go either way..
Old Apr 6, 2005 | 07:35 PM
it wasnt cherry red but it was nice n orange if i held it at 1/4 throttle in neutral
Old Apr 6, 2005 | 08:10 PM
86LT250RFatty's Avatar
rich makes it run cool.. if its glowing red its too hot, lean makes engines run hot. if its all stock, then something must be dirty in the carb, take the carb apart and clean it really good with carb cleaner. if you take the baffle out and airbox lid, go up 2 Sizes on the mainjet and you'll be fine with some more uummph.
Old Apr 6, 2005 | 08:37 PM
VelociRaptor350's Avatar
First you shouldn't have the lid off with a stock filter, it needs the lid to make a good seal so your not sucking crap into your motor. Second, you need to jet up for that much more air getting into your carb, if not you will fry your piston and your looking at a new top end.
Old Apr 8, 2005 | 01:29 PM
ok, thanks
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
