Warrior Possible Tranny Problem?
Old Apr 10, 2005 | 07:52 PM
Warrior02man's Avatar
Default Warrior Possible Tranny Problem?
I dno.. but when i am kicking down from 2 to 1, and then try to go to nuetral, it just goes from 1 to 2 and 2 to 1 when i try again. it completly skips nuetral. I sit there for like 5 minutes trying the same thing over and over, and it never kicks into nuetral. I eventually just shut it off and try kicking it into nuetral then, and sometimes it works. i dno whats wrong.. can someone help me out?
Old Apr 10, 2005 | 09:31 PM
chuck1's Avatar
I had an 87 and an 02 Warrior and had the same prob with both. They do that brand new. It was always hard to find neutral once they warmed up. I usually did the same as you - shut it off and then it would go in.
Shumway's Avatar
I have ridden many warriors, I have 5 buddies who all have them ranging from 88 - 2002, and I recently picked up a 2001. On every single one of them hitting neutral is tough. Now your clutch could be slipping, but ill tell you it took me a coupe days to get used to hitting [N], the key is that u have to lift up as lightly as possible. Trying to hit it going from 2 to 1 is almost impossible.
keep practicing, if all else fails what I use to do until i mastered it was turn engine off in 1st keep the key on and reach down and shift up to neutral using your hand.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 10, 2005 | 10:34 PM
VelociRaptor350's Avatar
Rock the quad back and forth and it will be easier to hit neutral.
Old Apr 11, 2005 | 12:04 PM
so its no tranny problem?
Old Apr 11, 2005 | 12:06 PM
Gwinnwarrior's Avatar
I DOUBT ITS THE TRANNY, MINE DOES IT TOO.
ROCK IT BACK AND FORTH OR MOVE IT AHEAD A FOOT OR SO AND TRY IT AGAIN.......................
Old Apr 11, 2005 | 05:11 PM
NLWarrior01's Avatar
Mine does it too .. seems to be an inherent trait with the Warrior .. my other buddy has a 2001 Warrior which does it too, but much worse than mine does. Mine goes in easily if I haven't been riding hard .. I've found the easiest way without shutting off the motor is to do it while coasting to a stop ...
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
