warrior problems leaving me stranded
Old Apr 14, 2005 | 10:27 PM
  #21
Lowbowtie1's Avatar
Default warrior problems leaving me stranded
The oil leak is more than likely not your problem. In fact the stator and pick-up coil is oil bathed and even if you looked at the stator you wouldnt be able to see anything wrong. To test a stator you'll have to pick up a manual and (i cant remember exact details) you'll have to check a few voltages off of the wiring harness.
The easiest way to tell if your having electrical problems is to check the spark with a good spark plug against the head.
Remember the 3 things an engine needs: Fuel, Combustion, and Spark.
Old Apr 15, 2005 | 01:02 AM
  #22
kbweathe's Avatar
Check your carb boot (the rubber part that connects your carb to the motor). Mine tore in the middle and I had simular problems.
Old Apr 15, 2005 | 07:54 PM
  #23
LOVINMYRAPTOR350's Avatar
thanks guys i got a clymer on the way ill keep ya posted !!!
Old Apr 15, 2005 | 08:16 PM
  #24
DollarBillz's Avatar
it sound's to me like the float is stuck and it only run's untill it run's out of gas is there anyway you may have bump the float when cleaning the carb's jmo
Reactant
Mar 30, 2022 02:08 AM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
cSchwartz
Jul 9, 2015 02:43 PM
