Problems with a conncting rod for a 2001 yamaha blaster. Pleas reply fast.
Old 04-16-2005 | 10:27 PM
Raptor350kid's Avatar
Default Problems with a conncting rod for a 2001 yamaha blaster. Pleas reply fast.
I just bought a 2001 blaster and the conecting rod is no good so would it be better to get a whole new crank shaft or just the new conncting rod and who would u suggest ordering them from??
Old 04-16-2005 | 10:30 PM
garrett5462's Avatar
i wouldnt get a new crank unless u have to.
Old 04-16-2005 | 10:33 PM
so u would just get a new conncting rod?? what about new seals or gaskets or barrons???
Old 04-16-2005 | 10:39 PM
TrailBlazerguy250's Avatar
if your connecting rod is bad i bet your piston is about shot , ied at least get a new connecting rod , bearings , and seals
ltandrew's Avatar
Get the new rod with a complete gasket and seal kit. Some of your old seals are probable ok but I wouldn't pass up the opertunity while it's apart.
Old 04-16-2005 | 10:41 PM
if it were mine ied do a new piston w/ rings , all bearing , all seals , and connecting rod , and wrist pin
Old 04-16-2005 | 11:24 PM
holeshotz8436's Avatar
and bore it to the next size so everything is nice and fresh and get the wiesco hot rod kit, cometic full gasket kit and i think pro x and wiesco both make pistons, or maby you could even go for the 240 kit check out www.cycleworksracing.net. they have everything you need and the prices are cheaper than dennis kirk.
Old 04-16-2005 | 11:29 PM
knew i for got something lol
njrider64
07-04-2017 01:40 AM
mikey426
06-17-2015 03:53 PM
Big600twin
14
06-16-2015 09:30 AM
Jbird4681
06-09-2015 01:59 AM
MrElussive
10-19-2000 09:50 PM
Quick Reply: Problems with a conncting rod for a 2001 yamaha blaster. Pleas reply fast.
