Raptor Choke
Old May 11, 2005 | 10:41 PM
u's Avatar
u
Default Raptor Choke
I think that my choke may in out of wack, The thumb lever has alot of play in the cable, I ve adjusted it but still seem to be the same. Iam pretty sure that it is affecting the way it idles, seems to run fine, Could there be something holding the choke open or shut?
Old May 12, 2005 | 12:46 AM
CTracingraptor's Avatar
disassemble it from the carb, all it reall yis, is a plug thingy, im not sure how it works, but take not, dont strip the black nut on the carb, its made of plastic. which your at it give everything a good cleaing with a bottle of carb cleaner(works miracles)
Old May 12, 2005 | 01:59 PM
jrobertson's Avatar
Mine broke, about 6 months after I bought it, the new kit from YamahaofTroy.com was like $12?, maybe $13.
Old May 12, 2005 | 03:13 PM
86LT250RFatty's Avatar
Mine did that. i took out the cable and the black screew thing off the carb where the cable goes in, and take out the little plunger and clean it and where it goes into, make it so it can slide in and out pretty easisly...
Old May 12, 2005 | 05:41 PM
quad2xtreme's Avatar
The spring might have corroded too located with the plunger at the carb. When I had my 2001, you couldn't get the spring without buying the plunger. I just went to the hardware store and bought a spring. Had to cut a few coils from the spring but it worked fine. Was less than $1 instead of like $27 if I remember correctly.
/jon
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
