blaster tranny oil
Old May 12, 2005 | 09:39 PM
centss's Avatar
Default blaster tranny oil
i have been running 10W-30 motor oil in my tranny for almost a year. the manual also states that is what should be used.
i was wondering what's the best weight to use and if synthetic oil is ok to use. i checked with my local yamaha shop and they lady behind the desk said synthetic may be too "slippery".
then i asked to talk with the mech there and she said he's too busy. so i have turned here for advice.
i have a qt. of mobil 1 synthetic 5W-30 but don't know if this would screw up the tranny?
Old May 12, 2005 | 09:52 PM
chazekxt's Avatar
i just use 10 w40 honda gn4 in mine works good
Old May 13, 2005 | 12:27 PM
Shav0's Avatar
Nothings going to screw up the tranny, but it may make the clutch slip, drag, or be hard on bearings. Id stick with what the book recomended. I use motul synthetic in mine, and have never had a problem.
Old May 14, 2005 | 02:11 AM
Blastermaster's Avatar
synthetic wont hurt a thing, just make sure you use the right kinda, make sure it has NO friction modifiers in it, they will make ur clutch slip, i personally run AMSoil, but from what i`ve heard on here mobile-1 with a red cap is the kind that has no fricton modifeirs in it, and 5-30 should not hurt it, the 5w-30 refers the rateing of the oils viscosity, and the 5W is winter and it refers to how fast the oil drains out of a certain size hole at a certain temp.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
1966F100
Aug 21, 2015 07:10 PM
