Kodiak 400 - Mud Tires & Clutch Kit - CRAPPY in mud
Old 06-28-2005, 06:42 PM
kawasaskirules's Avatar
Default Kodiak 400 - Mud Tires & Clutch Kit - CRAPPY in mud
soo your saying i shouldn't get a clutch kit and save up for a pipe or sumthing else
  #22
Old 06-28-2005, 09:25 PM
kodiakman5's Avatar
i have the same problem with my kodiak 450 did the clutch kit help at all, i'm looking to fit the problem to. NO low end and bogs down in mud. now mine has a bad hesitation in any water too. where did you get the kit and hard hard to install
  #23
Old 06-29-2005, 02:29 AM
2FAST4URASS's Avatar
http://4wheeldrive.about.com/gi/dyna...tirewheel.php3 GO THERE AND TALK WITH SCOT HE IS THE GURU OF AUTO ATV'S AND IM WILLING TO BET MY LEFT NUT HE WILL GET WHAT YOU NEED TO TURN OVER THEM TIRES.
  #24
Old 06-29-2005, 02:38 PM
hondabuster's Avatar
DigitalFusion
When you get your father in law to remove some material, remember to let him know you want a 10% reduction in weight , not diameter...its different. Youll probably need to use a scale ...i used my reloading scale, because they dont weight much...somewhere around 20 grams. I think the inner material is aluminum, and the outer shell is a plastic material, like teflon. I suppose its plastic in case the grease ever comes completely off of it, then it will still have some lubracation.
Some people have done every other weight, and have claimed it made a difference, but i think youll need all of them done. My 450 has 8 weights, and the bruin has 6...im not sure how many are on the 400, but ive heard its 6. I havent heard of anyone whos tried the secondary spring from a bruin 350 in a kodiak 400, but it might be worth a try, and i cant believe it would be very expensive.
Have you got a link to the web site for those epi weights?
Let us know how it goes...im interested.
  #25
Old 06-29-2005, 03:22 PM
DigitalFusion's Avatar
I think I may just try drilling holes in them like some others suggested. I will start with a very small bit and one hole in each, and go from there. The EPI weights are here:
http://www.erlandsonperformance.com/new/ATV-yamaha.php - Then just click on the clutch weights in the menu.
STLyamwar
07-25-2020 04:44 AM
txpedsrt1
02-03-2017 08:07 PM
07-28-2015 12:12 PM
RedRancher
07-10-2015 06:36 PM
Quick Reply: Kodiak 400 - Mud Tires & Clutch Kit - CRAPPY in mud
