*warrior starter problem?*
Old Aug 3, 2005 | 01:46 PM
mRt86's Avatar
Default *warrior starter problem?*
Ok my warrior hasn't been running for the last week, it wouldn't even try to turn over and if I crossed the sylenoid it wouldn't do anything eather. When I bought the bike the guy gave me an extra starter so I put that in it and now if I cross the sylenoid and listen carfully I can hear the starter try to turn over. Oh yea when I cross he sylenoid huge sparks start shooten out. bigger sparks than I ever seen shoot out of a syeloid so now I don't know whats wrong with it. Is it the starter? the sylenoid?
Old Aug 3, 2005 | 01:51 PM
warriorboy22's Avatar
well if the starter is brand new then its probably the sylenoid
Old Aug 3, 2005 | 04:10 PM
mRt86's Avatar
no the starter is used, I just wanted to see if it worked, thats probly why it was an extra, their both probly broken
Old Aug 3, 2005 | 06:54 PM
UltimateAussie's Avatar
you can buy factory reconditioned starters on evay for like 80 bucks
Old Aug 30, 2005 | 08:21 PM
recon99's Avatar
if you're shorting out the solenoid then that's not the problem, that bypasses the solenoid. You probably have a bad starter.
Old Aug 30, 2005 | 09:29 PM
BOOV's Avatar
my warrior did the same thing i bought anew 1 and it was fine good luck tho
Old Aug 31, 2005 | 12:39 AM
YFZ450kid's Avatar
hey, if you have the pull start backup option, there is the decompression switch on the front of the motor, flip that and try to start it... it may be a really week starter, and I havent seen anyone post anything about a battery...??? just a thought... if the starter is trying to move the motor, by hitting that little switch it will have virtually no compression and should turn over much easier...
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
