Banshee troubleshooting
Old Sep 5, 2005 | 03:07 PM
mawcus's Avatar
Default Banshee troubleshooting
Originally posted by: cruddymutt1
The pinging makes me think more of a predetonation. Have you advanced the timing at the stator at all?
As far as I know,its stock timing.I've got the carb apart now and I'm cleaning it good and going from 3rd to 4th needle clip position,and a 310 to 340 main.It seems to get hot real fast when ridden hard,so I'll experiment a bit.And I'll stay posted.
Old Sep 6, 2005 | 05:09 PM
Storj's Avatar
dont run to rich because running to rich is just as bad as running to lean
Old Sep 6, 2005 | 05:34 PM
garyc660R's Avatar
Originally posted by: cruddymutt1The pinging makes me think more of a predetonation. Have you advanced the timing at the stator at all?
You need to contact the previous owner and check on timing and compression. Timing a shaved head could easily go unnoticed. After that, what kind of pipes are you running? No way you should be running 340's unless you are running drag pipes. At a minimum you need larger pilots and an aftermarket set of pilots over stock. The aftermarket needles have more taper for more fuel on the idle circuit-mid range transition....and of course the pilots allow for more fuel as well. Call any place that sells your pipes and they should have a needle/pilot kit for the Banshee. Everyone sells them with Banshee pipes for a reason.
Gary
Old Sep 6, 2005 | 06:54 PM
DaBeechMan's Avatar
running too rich is NOT the same thing as running too lean.
Its a simple do...take your plug out...if its black its rich, if the porcelin has a mocha color to it you are close. If its white you are lean.
pgamboa
Dec 24, 2023 11:52 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
