Taking a link out of chain
Old Sep 4, 2005 | 12:51 PM
tbscrammy500's Avatar
Default Taking a link out of chain
can someone please tell me how this is done on an oring chain?
Old Sep 4, 2005 | 12:54 PM
Storj's Avatar
you need a chain cutter
Old Sep 4, 2005 | 01:23 PM
so theirs no way to shorten the chain w/ out a chain cutter???
Old Sep 4, 2005 | 01:39 PM
mRt86's Avatar
I did it with a grinder, a punch and a hammer
Old Sep 4, 2005 | 01:53 PM
how is it done?
Old Sep 4, 2005 | 02:01 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You can grind off the pins to slightly below flush with the outer plate and then pry the plate off. Then push the other half of the link out.
Old Sep 4, 2005 | 04:22 PM
mRt86's Avatar
yes, grind the head off the pin then take a punch to knock the pin out....Iv done this to many chains
Old Sep 5, 2005 | 11:13 AM
quadbart's Avatar
Did it ever occur to you guys that if your chain is stretched to the point where you need to remove a link to make it fit right that maybe you need to REPLACE IT ??????
A $60.00 chain is a whole lot cheaper than replacing a tranny axle or an engine case after youve snapped the chain and it wraps around the counter shaft.
If you cant afford to fix it right than you cant afford to own an ATV, Sell it to someone that will take good care of it.
Old Sep 5, 2005 | 02:00 PM
mRt86's Avatar
Or maybe a chain comes to long and a link needs to be takin out to make it short enough to fit.
Old Sep 7, 2005 | 08:03 AM
KTM Patrol
Former Chinese POW!
Actually it did occur to me, but that wasnt the question. I usually replace sprockets and chains as a set but I realize some cant afford that.
Cole Hadden
Jun 15, 2025 09:05 AM
RticKwad
Jul 21, 2015 03:00 PM
95wolv
Jul 17, 2015 08:13 PM
cSchwartz
Jul 9, 2015 02:43 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
