banshee questions
Old Sep 14, 2005 | 07:42 AM
mawcus's Avatar
Default banshee questions
Thanks but no ma radiator isnt clogged,I do ron w/o my overflow rezzy,tho.
Old Sep 14, 2005 | 07:52 AM
paintballbanshee's Avatar
Are u sure u double checked to make sure nothing is clogged? if not u need to double check
Old Sep 14, 2005 | 10:09 PM
mawcus's Avatar
Does getting hot cause your jetting to lean out a bit?Maybe I'll move my clip down a notch and check back.
Old Sep 14, 2005 | 11:02 PM
NBake's Avatar
what throttle position does it cut out at? are u full throttle? 1/2? 1/4? 1/8? id say try turning ur air screw in a half to a full turn and see what happens. if ur hitting the powerband fine but cant get into it easy, kinda sounds like ur bottom end is leaning out as it gets hotter. but ur main and needles are set good so the powerband still rips like hell. based on my experience w/ jetting my bike, when the bottom was lean but the main was good, it would bog at like 1/4 throttle then all the sudden hit the powerband and rev out fine. play around with ur airscrew to see if anythin happens
Old Sep 15, 2005 | 08:07 PM
  #15
mawcus's Avatar
Thanxx..Appreciate the responses.I tried the air screw(turned in 1/2 turn) yeah it made a big diff in bottom end.I don't even need to gas it to take off now.I'll try the needle clip next chance I get, and stay posted.By the way, think it's 3/4 throttle to full throttle,BUT ONLY at high rpm's,before really hitting the powerband.It dont do at low rpm's,even at full throttle.
Old Sep 16, 2005 | 08:07 AM
  #16
MDS2106's Avatar
Marcus,If you gettin sick of that thing I'll take it off you're hands. LOL Do you know off hand what jetting you have in the blaster ?I sent Daniel's cylinder off for port and polish this week ,I'm sure I will need a starting point with the jetting when I get it back.
later,
Mark
Old Sep 17, 2005 | 12:26 AM
  #17
mawcus's Avatar
later,
Mark
Sorry man,not for sale.[img]i/expressions/face-icon-small-smile.gif[/img]Oh yeah 310 mains(had them in BEFORE the port and they seem fine now,too.)Weird.Man I think myblaster will beat a yfz now.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
