Warrior Rejet and Carb question
Ok. Me and Warrior boy are having problems with our Warriors... When I starrt mine up, it runs fine for like 3 seconds then revs really high, then calms down. and like after letting it warm up, not riding it, it will keep reving up really high, then going down like its gunna die, then it seems like it cant just sit and idle. Do we possibley need to rejet or what? Anyone help me with what jet sizes I would need? I also need help with that problem above.
Elevation 600ft
Current jet size 152.5
Supertrapp Pipe
366 Big Bore kit (Supposidly, Guy said it had one)
DuraBlue Axle,
Stock Headpipe
I think thats all.
Im thinking about getting a Dyna Jet kit, but what size Minuki or w/e jet should I have?
Elevation 600ft
Supertrapp Pipe
DuraBlue Axle,
Stock Headpipe
I think thats all.
lol I just put a carb rebuild kit in it... so idk... it ran ok before the kit, but yea... idk whats wrong with it now.. it was running for like 10 mins idling fine, then it would just die, and I could start it back up, but it died a little later.. Any idea's? My Idle screw thing went from being like 5 turns out, to all the way in, to like 3 turns out... within an hour... cause it kept acting up
Carb looks fine, and its a new carb boot. lol. so it should be fine. But my exhuast is leaking, like there is a clamp thing right below the reverse level thing, and its leaking out towards the engine at that spot, I was thinking maybe I could just weld it closed and take the clamp off. Bad Idea?
my exhaust leaks alittle there too. dont weld it, it would make it too hard to get the exhaust off later. if it ran fine before the rebuild, you probably screwed something up. pull the carb apart again and double check everything.
but its not only mine. He hasnt had his rebuilt along time ago, and it ran fine, and all of a sudden it started doing this. Any more idea's?
