warrior smoking help!!
Old Oct 2, 2005 | 02:39 AM
jasonswarrior85's Avatar
Default warrior smoking help!!
for some reason my dads warrior is putting out a white smoke. checked the oil and was low, filled it back up and let it idle for alittle bit and its still smoking alittle bit. does anyone know what is happening here?
Old Oct 2, 2005 | 10:23 AM
95wolv's Avatar
Sounds like you either have worn rings, or the valve seals are leaking by pretty bad. To check rings, take a compression reading, then squirt a little oil in the cylinder and take another reading. If it is higher, the rings are worn ( the oil helps to temporarily seal the worn rings). If there is no change, more than likely you have valve stem issues, or the rings are so shot the oil can't help. Also, make sure the oil level is correct, overfilling will cause the motor to suck up the extra oil and burn it, then it tends to keep blowing out the oil until it gets low.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
