FCR/LTE Clearance
I finally fitted my LTE pipes to the raptor. My concern is that after modifying the midpipe to clear the accell pump on the FCR that it might still be too close. I have 1/8 inch clearance from the frame and 3/8 inch clearance from carb, is this normal and can the FCRs handle the heat. I have tried wrapping the pipe with exhaust heat wrap but that makes even less clearance. Any suggestions or will it be OK?
