01 Banshee bogging down
Old Nov 15, 2005 | 08:23 AM
loonatic72's Avatar
Default 01 Banshee bogging down
Any one have any ideas why my banshee would go from running great one day to bogging down and barely running the next?? I've taken the carbs apart and cleaned them changed the plugs and cleaned the air filter. The engine has a fresh rebuild on it and has only been ran about 3 hours so far.
Old Nov 15, 2005 | 11:54 AM
enFORCER's Avatar
Check and make sure your parking brake is off. If it is on, your Banshee will NOT rev up. It will just bog down when you give it gas....Did you check your compression? It should be around 125psi or so on both cylinders....
Check and make sure you have a strong spark as will, could be an ignition problem.....
If these things check out ok, then its most likely your carbs......
Old Nov 15, 2005 | 11:57 AM
enFORCER's Avatar
Oh one more thing..... It could be your T.O.R.S. Unplug it........
Old Nov 15, 2005 | 11:58 AM
enFORCER's Avatar
Make sure your parking brake is NOT on...... If it is, this will effect the T.O.R.S.
Old Nov 15, 2005 | 06:04 PM
loonatic72's Avatar
It's getting plenty of compression, the emergency brake isnt on, unless somethings messing with it. Wheres the T.O.R.S??
Old Nov 15, 2005 | 07:38 PM
enFORCER's Avatar
The connector plug is located on the upper left side of the frame, behind the radiator....
Old Nov 15, 2005 | 10:56 PM
Six2notScaredofU's Avatar
Cut the wires on your parkbrake. Mine did the same thing
Old Nov 15, 2005 | 11:25 PM
loonatic72's Avatar
Yeah I went out and srewed around with the e-brake and the bike fired right up and run but back fired a couple times. I did notice that the e-brake was moving some so I held it in place and the bike still back fired a little but reved up good. Thanks for the help if anyone has anymore ideas please let me know.
Old Nov 27, 2005 | 04:52 AM
CertifiedDunatic's Avatar
get carb rebuild kits, mine was having the same problem. It turns out that it had two different styles of needles
Old Nov 27, 2005 | 06:04 AM
atvaddict01's Avatar
Do you have a clean air filter?
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
