rapter reverse
Old Nov 6, 2000 | 01:02 PM
RaptorWarr's Avatar
You use an 11 tooth? Did you increase tires to 22"? How is it for chain wear? That sound like a very tight radius for the chain.
Old Nov 6, 2000 | 01:14 PM
4hacks's Avatar
He ordered a 12 tooth front from Renthall and a 43 tooth in back. They said it would be roughly the equivilant to an 11 tooth in front without the tight chain radius. He gets it this week.
Old Nov 6, 2000 | 02:14 PM
xtreme165's Avatar
Ya I run a 11 front and stock 40 rear, it works fine the chain and sprocket may where a little faster but not to much its worth it. You could go up to a 43 in the rear and a 12 in the front as the comment below suggest but you'll have to shim your rear skid plate down and you'll loose ground clearance I wouldnt recomend doing this because the thing sits low enough already. I have full prm skids on my raptor I would recommend them to everybody there great, the stock swingarm skid offers no protection (plastic). Try an 11 if you race HS or woods ride and you'll love the differance. I also just put a set of razors on the back with banshee wheel and I off set the wheels this lets the raptor corner at high speed great the razors enable the quad to slide and the wheels give it a little wider stance for steep off cambers or high speed turns its a awsome combo.
Old Nov 6, 2000 | 02:16 PM
xtreme165's Avatar
No I didnt go to 22" tires I put 20" razors on it, I'll run the stock radial in the winter.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
