warrior carbs
Old Jan 22, 2006 | 09:08 AM
YamahaRider8998's Avatar
Default warrior carbs
wat is a good site to get a nice carb for a warrior that will take away that bogging down wen u accelerate too fast. I dont want to burn a hole in my pocket so the best carb for the lowest price and wat site
thnx
steve
Old Jan 22, 2006 | 11:32 AM
warriorboy22's Avatar
the best carb is edelbrock and i have been told its completly worth the $350 you can get it for new on ebay but its like $550 from the website.
Old Jan 22, 2006 | 08:58 PM
Thnx does anyone know if a white bros carb is any good, i saw it on alba. Also does anyone know if it that difficult to install a carb, can i do it on my own cause i have done some stuff like replacing the axle housing, sprocket and chain stuff , jw how difficult it is especcially if i got a prejetted white bros carb.
steve
Old Jan 22, 2006 | 11:01 PM
recon99's Avatar
There's 2 WB carbs, the $200 one and the $400 one. The $200 one doesn't have an accelerator pump, so the throttle response will probably be even worse than the stock carb(which has an accelerator pump, just a weak one). The WB with the accelerator pump is more expensive than the edelbrock, and you're not guaranteed that it will be any better than your stock one. The edel is the only way to go on this one if you ask me.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
