01wolverine squeaks when backing up
Old Feb 16, 2006 | 08:37 PM
drac1's Avatar
Default 01wolverine squeaks when backing up
did that already used blue lable chain lube stuff is awsome good for rubber .the only think that it may be is the brakes put new pads all way around ...i never made this noise befor i did this stuff lol.man i dont know later dave
Old Feb 16, 2006 | 09:24 PM
wolverine68's Avatar
Did you accidently put both brake pads on one side of the disc? I would suspect front or rear drive shafts(u-joints). Does it squeek when you bounce on it (suspension) or when it's moving(drivtrain)?
Old Feb 16, 2006 | 09:33 PM
drac1's Avatar
did u say 2 pads on one side no front to the front and rear to rear i made shure,i greased the shafts the whole front end with a bike pump niddle.and lubed everything could it be the cv boot no grease i need to check that tonight ,but its funny when i brought the bike in the garage no squeaks when im done .all new breaks new bearings and seals in back,and new bearings and seals on right side it squeakscould it be the breaks .if i jack it up spin the wheels nothing,and why ony in reverse.thanks dave
Old Feb 16, 2006 | 11:24 PM
drac1's Avatar
well i think i found what it waz i jacked all 4 wheels and spun then then i seen the the cover for the front drive shaft waz moving took it off and bam broken u joint i dont even know how it waz drivable .now need to see what i need do i just get the u joint or do i need the shaft too if soo maybe get warn 424 ....
Old Feb 16, 2006 | 11:53 PM
  #15
If your yokes are good, you just need new u-joints. Don't get them from the dealer though as they are scary expensive. Any bearing supply house should have one that is very close for less than 1/4 the price. Let me know if you need the part #.
Old Feb 17, 2006 | 12:06 AM
  #16
drac1's Avatar
wow part number would be grate if ya got it handy if not no prob ill just take it to a bearing place ,thanks dave
Old Feb 17, 2006 | 12:22 AM
  #17
No prob. I got all the part #'s written down so I don't have to dissassemble to get the new parts. The u-joints are: PTS Nea-1-0028.
Old Feb 17, 2006 | 08:47 AM
  #18
drac1's Avatar
thanks alot the u joint is also call the spider. its on yamaha finch cards look up thanks a million bro and again thanks wolverine 68
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
